Thread: Sticky ignition
Old Jan 24, 2017 | 01:27 AM
Whitcat9's Avatar
Whitcat9
Default Re: Sticky ignition
Correct. Engine does not turn over. I have already read the post your referring to. Car ran just fine before key got stuck. I'm guessing it's the switch assembly. I read that if you connect the bottom half of switch assembly to main switch assembly you can start your car without key. (Keep in mind this is with key/ignition assembly removed from car). Is this true? If so, how is it done? If I could try this out first it would save time before going under hood.
