Old Jan 24, 2017 | 08:56 PM
Robert Andrew's Avatar
Robert Andrew
Default Re: Traction Control
Originally Posted by chuK_138
Are you in manual mode or in drive when you're doing this? Also, it's the TCU tune that changes the S/W switch mode.
I've tried it in every conceivable configuration, and it's always the same. Buggin suggested that I check the fault codes, and I forgot that it had an OBDII, blue tooth module in it so I downloaded Torque and it was showing a P0410, Secondary Air Injection Code. I just got home, so I haven't researched that fault code yet. Thanks for the response.
