oledoc2u
Well, just trying figure out his problem. My TCU tune was just to match up with the 3:46 rear end. But I will keep that in mind lol. His problem sure sounds like an inner cooler pump but says it has been replaced. I had my throttle peddle comes loose from the mount which limited my throttle...took a little bit before I figured out what was wrong. Thank Chuk...
Hi Doc, I misstated the comment about the intercooler pump. I have two other Crossfires SRT6s and I have replaced the pump in both of those, but not this one. I don't think that is the issue, because if you play with the throttle, it will come to life and blast off. When it's on it's much faster than my stock SRT6, and when it is off, it really is waaaay down on power. At Buggins suggestion I pulled the fault codes and it was showing a PL0410, Secondary air injection fault, which I haven't researched yet.
Thanks,
