Old Jan 24, 2017 | 09:08 PM
Robert Andrew's Avatar
Robert Andrew
Default Re: Traction Control
Originally Posted by oledoc2u
Robert. I read your other post. Your winter mode will start you out in 2nd gear. So you will want to stay away from that. EC tune does not do anything with the W/S mode. You should not be getting all this bucking you are talking about with or without traction control on or off. Make sure you didn't unlodge the throttle peddle from it's mount. If you did, this will limit your throttle peddle's movement. It slips onto a flat piece of metal. I can't imagine you having a throttle body problem, and you stated in your other thread you have replaced the pump before. Only thing left would be fuel. Check that throttle peddle....you really have to get under to see...if it is mounted properly.
Thanks for the suggestion. I did have the throttle pedal off to remove the carpet, so I check it and it is in place properly. It does have a Sprint Booster, which is apparently in the slow position, because my other Crossfire is much more sensitive. I've never installed a Sprint Booster, I'll see if I can find the instructions and verify that something didn't come loose on it. At Buggins suggestion, I pulled the fault code this evening and it is showing a PL0410 code, alternate air injection. I haven't researched that yet.
