Old Jan 25, 2017 | 02:20 PM
  #4887 (permalink)
ian6760's Avatar
ian6760
The glitch in the system is in your car, understand that and we can go from there.
Ok, fair enough.
When you say siren box you mean the siren that is in front of the windshield hidden under the plastic cowl. You have changed the batteries in it and then replaced it.
Yes that's the one.
I bought the batteries and when I opened up the siren it had seen better days. I stuck the batteries in anyhow to see if it worked but it didn't fix the problem.
Next, used siren fitted, no fix.
Does the gas cap door lock when you lock the car using just the fob?
If not then the air line to it could be broken. It operates on its own air line. Could it be possible that the alarm light does not come on if this gas cap lock does not work properly?
The gas cap locks several seconds after the doors on the fob. I presumed this was a safety feature to enable the doors to lock and not the gas cap when stopping for fuel.
Disconnecting the siren under the cowl does not have any effect on the alarm system, only the lights will flash if the alarm system is triggered.
I know, I took the siren off because it was going off all night, I'm not so bothered about the flashing light. Not unit the car goes flat if not used for a few days.
