Re: What did you do to your Crossfire today?
ian6760
Ok, fair enough.
Yes that's the one.
I bought the batteries and when I opened up the siren it had seen better days. I stuck the batteries in anyhow to see if it worked but it didn't fix the problem.
Next, used siren fitted, no fix.
The gas cap locks several seconds after the doors on the fob. I presumed this was a safety feature to enable the doors to lock and not the gas cap when stopping for fuel.
I know, I took the siren off because it was going off all night, I'm not so bothered about the flashing light. Not unit the car goes flat if not used for a few days.
The gas cap door locks at the same time as all the others on my car.
When you had the pump out I presume you mean the one under the foam in the trunk/boot?
Can you easily access it now? Or is it all covered again?
