Old Jan 26, 2017 | 09:18 AM
Rpaczan's Avatar
Rpaczan
Default Re: Chrysler Crossfire Garage Door Opener & Cig Lighter
I also got one from Mopar Parts Overstock, their shipping and handling is higher so I bought several more items to make it cost effective. I installed one I got here in the SRT. It's an easy install...take off the passenger vent cover (1/4 turn of plastic fastener, careful not to strip head); remove screw behind cover, slide trim to the right and pull forward; take and push lighter housing out from behind (plenty of wiring length); you may need to use a small trim tool or flat headed screw driver to apply some leverage on front of outlet between bezel; (housing is held in by two small clips. Took about 10 minutes.
