Thread: Sticky ignition
Old Jan 28, 2017 | 11:16 AM
onehundred80
Default Re: Sticky ignition
Originally Posted by Whitcat9
To make a long, long story short, I screwed up. Don't even ask me why. You'll figure it out soon enough. My question is; Ignition switch... need to replace because I permanently locked it.Now... will a new switch work with old lock assembly? Or more likely do I need to replace whole lock cylinder housing as well as getting a new key and tumbler? Can you mix old and new parts dealing with the lock cylinder and ignition switch? Everything works fine until I get to ignition switch.
Sit back and take a deep breath. Go through the PDF and see that you have attached everything as it should be attached. If necessary do the taking apart and reassembly process again.
I cannot see how you could fail in this.
Just make sure that the Halo around the ignition keyhole does not get pulled on, this could unplug it at the other end by mistake. This is not your problem right now, I go with my earlier comment about the interlock cable.
