Thread: Sticky ignition
Old Jan 29, 2017 | 04:24 PM
KDW4Him's Avatar
KDW4Him
Default Re: Sticky ignition
Originally Posted by Whitcat9
Car is manual. As I said before, I can turn key to position "1", dash lights come on, lights come on, security ding comes on, power windows work, door locks work, electrical is fine. Can put car in "D", "R", "P". Steering wheel turns. When turning key from position "1" to position "2" nothing happens. Turn key back to position "1" and then to position "2" it feels like it freezes up. Put my foot on brake to start car same as above, turn steering wheel, same as above.
OK, this tells us the tumblers ARE fine AND the gearshift interlock is connected properly so we can eliminate that.
Did we establish you did put the antenna ring around the tumblers and that the wire didn't pull out of the SKREEM module on the other end?
Could you have blown a fuse to something while working on the car? Did you check them or was the battery disconnected during the disassembly reassembly process?
^^^^^ James could be onto something, I cannot test mine either.
