Thread: haywire
Old Jan 29, 2017 | 04:35 PM
KDW4Him's Avatar
KDW4Him
Default Re: haywire
Originally Posted by Joe_comedian
Hello group.
I have a 2005 lmtd Roadster, we left it while on vacation for a month and the battery went dead, meanwhile the rear window was also leaking, so once new battery installed, everything is haywire, rear spoiler goes up when i shut off the car, the interior light only comes on after i go in the house and burns the battery up, or with on switch but not when doors are open, top doesn't work, tow button is lit, none of the locks work, lights flash with remote and i hear a click under the front hood, but nothing else and no hissing. gas door and glove box do not open. also previously no high beams. seems power loss too.
and I may have two problems, one could be water might of got into trunk and motors. but I can not open the trunk.
so for starters how do i open the trunk? i have seen conflicting posts, one say right license plate light others say left, i don't want to damage both in an attempt to open.
Update, the parking lights are on and will not go off, the tow button is lit, the top has a light that is flashing, so i disconnected the battery to not kill it. when i reconnected the next day, lights still on, but the tow and top or off but now the spoiler is flashing and does not manually work, but does still work at speeds. ??? anyone??? help??
Check the troubleshooting section on here for the way to open the trunk. Seems you removed a side marker light (EDIT DS TAG LIGHT) and use coat hanger to pull the emergency release.
