king happy
I have been told that pure water dissipates more heat then antifreeze . the car is in s. florida and well never see temps below 50 degrees , so anti freeze is not needed . It is an str6 and i'm adding mods to it so max heat dissipation is the goal .
what does everyone recommend to add to distilled water to prevent rust and corrosion ?
You have to remember, antifreeze ALSO contains anti boilover chemicals as well. You should use a 50/50 mix all year!
