Old Feb 16, 2017 | 08:05 AM
ala_xfire
Default Re: blinking fuel light check engine
Originally Posted by Jjtow007
thank you!!! I didn't even think about to that! Thank you for the bet diagrams too! Can you tell me if the fuse panel is located in the cab or under the hood?
The lighting fuse panel is actually a part of the headlight switch, remove the cover on the driver side dash to access.
NOTE : Anyone know why the low beams are on a 15 amp fuse, while the high beams are on a 7.5 amp fuse ?
