Re: Picture of my Crossfire at February Autocross
It has the H&R 30mm front bar and stock rear bar. It pushed with the stock 25mm front bar, but I've had no issues with the H&R bar. I agree that it's almost totally unloaded on the right with the Koni Sports set on full stiff. I think that I could use more negative camber. I have the "crash" bolts but have not installed them yet. With the 7.5x17 front wheels (stock offset), I have very little space between the tire and upper spindle mount. I had spacers on the front but they caused a balance issue; so I don't use them anymore. I haven't had the alignment checked; so that's the first step. Then I'll decide about the "crash" bolts. If you notice the cone behind the car, this portion of the course probably had the shortest distance between cones in this slalom.
