Old Feb 18, 2017 | 03:45 PM
Padgett's Avatar
Padgett
Default Re: Need Help!! Stranded
[QUOTE=SrWilliams;882178]I never thought to check for warning lights . I will do so.
"can I pour gas down the manifold. If, so, hw would I go about doing that ?" Sorry, if you have to ask it is something that is potentially unsafe and could lead to an engine fire.
The real answer is to put a fuel pressure gauge on the fuel rail and see if maintaining at least 30 psi pressure. Your sysmptoms match a partly clogged fuel filter, fuel line, or failing fuel pump that lets enough seep through for the engine to start but does not maintain enough flow to stay running.
