Thread: Pulley shaft ?
Old Feb 21, 2017 | 09:34 AM
dedwards0323
Default Re: Pulley shaft ?
Do you think a person using a strap wrench could exert more pressure than someone using a breaker bar?
My breaker bar is 24" long and someone using a 12" strap wrench would have to exert more than twice the force on it.
Anyway the screw must be replaced with a new one, the last thing you want is the old one being used and breaking.
I do have a 12" strap wrench in my tool box, but that is for small jobs that don't require much holding power. One needs a heavy-duty strap wrench (see attached) to hold a pulley to loosen a bolt torqued to 150 ft-lbs. If I can get that strap wrench on & secured, the crank holding bolt comes loose. I know there may be doubters about this, but I've done this multiple times in similar applications and know it works.
And I agree that the holding bolt needs to be replaced if this service is performed. Not worth the risk to have to do this again due to a bolt failure caused by fatigue from previous pre-load.
