Old Feb 24, 2017 | 01:25 PM
performanceisland's Avatar
performanceisland
Default Re: Fuel rail test port on srt-6 supercharged engine
Originally Posted by amx1397
your filter is the regulator make sure you replace with the correct one or install fuel pressure regulator other wise u will have somewhere 100 psi. jim
I know.
Does anyone know what the factory filter flows? i have a pierburg slk55 amg pump, but the check valve is going, so going to install a check valve, my options are new factory filter, or the high flow filter with no regulator, but then i need to install a seperate regulator, the slk55 amg pump comes with the high flow filter i think, cause it only has two ports, no third.
Are there different part numbers you guys are using with regulator already inside or just the factory oem one and the non regulator high flow filter from slk55 amg?
