Dashboard error lights !
This is my first post so forgive me if it does not appear where it should. I have an issue with my 2004. Have owned this Crosssfire less than a year and had no problems. Several days ago the brake light appears along with check engine , brake wear , abs , bas esp , and speedometer / odometer stops working. Spoiler is up and I can move it down for a moment when key first on , but it goes to full position itself. Brake pads were getting thin so i replace and check fluid. This did not correct problem. Code is P0600. Lots of possibilities posted but the speedo not working seems odd in this mix. Thoughts or suggestions would be a great help
