Old Feb 25, 2017 | 12:50 AM
ala_xfire
Default Re: crossfire battery problem please help!!!
Some have found this to be caused by the OEM radio, but the only way to be sure what is draining is to hook up an amp meter ( cheap multimeter on the high DC amp scale ) between the negative battery terminal and the cable.
Start pulling fuses in the underhood fuse box one at a time while watching the meter.
When it drops back to somewhere around 30 milliamps, you have found the source.
