S8MS-01904
OK, I have arrived and touched the Crossfire.
Keyfob doesn't unlock the doors (suspect battery in fob), but not sure. It's too late to open door with key, so I'll do so in the morning.
Will alarm sound or mostly grind until the main battery is dead? I may have to unplug this until I get it home.
I'll keep posting as I discover things.
If the alarm goes off, the car will not start.
What is the point in having a key lock in the door, if it can't be used ????????
I have a 97 dakota the same way, if doors are locked, only way to unlock is with fob, if use a key, the horn goes off and truck will not start.
Could be just weak, walk around the car pushing the button???
