Thread: Parts for sale
Old Mar 4, 2017 | 01:43 PM
ichon's Avatar
ichon
Default Parts for sale
CROSSFIRE PARTS
PRICES ARE PER ITEM AND INCLUDE S/H.
REASONABLE OFFERS ACCEPTED.
2 05097959AA FRONT SPLASH SHIELD $55.00
1 A1936900925 INTERIOR REAR TRUNK PANEL/TRIM $50.00
1 A0005401688 RADIATOR FAN $125.00
1 A0015400188 COOLING FAN MOTOR $200.00
1 75897 14120 12v UN I BLOWER MOTOR $25.00
2 05059163AC TAIL LIGHT WIRING HARNESS $20.00
1 A1122010601 WATER PUMP $65.00
1 A2316449 LEFT OEM MIRROR $10.00
1 A2316454 RIGHT OEM MIRROR $10.00
2 A1705450305 RELAY CONTROL MODULE $410.00
1 2025402373 OEM OBD DIAGNOSTIC PORT COVER $25.00
1 A1131410125 OEM 74mm THROTTLE BODY --- SOLD
3 2108206210 HVAC HEATER BLOWER MOTOR $100.00
1 A0005504883 INTER COOLER PUMP $75.00
1 2025450314 IGNITION SWITCH LOCK $10.00
1 68001655AA IGNITION CYLINDER LOCK HOUSING $200.00
1 A1120900129 AMG OEM AIR INTAKE CLEANER $50.00
1 A1120941482 INTAKE HOSE $15.00
1 392022010 ENGINE AUXILARY WATER PUMP HEAD+HOSES $35.00
6 A1121500118 AMG OEM IGNITION CABLE $75.00
2 A1121500618 AMG OEM IGNITION CABLE $30.00
2 A1121500718 AMG OEM IGNITION CABLE $30.00
2 A1121500218 AMG OEM IGNITION CABLE $30.00
1 NNO CST COOLANT RESERVIOR CAP $20.00
8 A0021403560 DIVERTER VALVE $200.00
1 05098305AA HVAC BLOWER MOTOR HOUSING $175.00
1 NNO AFTER MARKET UPPER GRILLE (BLK) $75.00
2 NNO AFTER MARKET LOWER GRILLE INSERT (SLVR) $25.00
2 05134572AA OEM SRT6 REAR CONTROL/CAMBER ARMS $60.00
1 A1718202526 ALARM SIREN $20.00
5 NNO OEM VALVE STEMS + CAPS $40.00
1 NNO OEM OIL FILTER CAP (WORN) $5.00
1 A2023300118 MB ECCENTRIC BOLT KIT $15.00
20 NNO HD 1/2" LUG NUTS $18.00
2 A1706800235 OEM DOOR SILLS $55.00
1 A1936900125 LH DRIVER SIDE A PILLAR $35.00
1 A1938300085 CLIMATE CONTROL UNIT $125.00
1 A0255455932 RADIATOR FAN CASTER RELAY MODLUE $100.00
1 A1938300354 LEFT DASH AIR/LIGHT VENT COVER $50.00
1 A1938300254 RHT DASH AIR/LIGHT VENT COVER $50.00
1 A1706830326 UNDER STEERING WHEEL TRIM/PANEL --- SOLD
1 A1938200121 ALARM ECU MODULE + BRACKET $55.00
1 A1708300166 LEFT OEM FLOOR OUTLET VENT $35.00
1 A1122370740 OEM SRT6 PULLEY/HALTER $24.00
5 NNO OEM KEY FOB CASES/SHELLS $55.00
1 05099817AA OEM OXYGEN SENSOR $300.00
4 A2103250384 OEM REAR RUBBER SPRING SHIM/BUFFER $45.00
3 05098200AA TRANSPONDER TRIM RING $160.00
1 A1704620057 IGNITION PROTECTIVE CAP $45.00
1 4686795 TURN SIGNAL RELAY MODULE $15.00
1 82208313 MOPAR WHEEL LOCK KIT $55.00
1 A1938200721 LEFT FRONT SIDE MARKER $40.00
2 NNO CHRYSLER NEW WING CARBON FIBER PEN $50.00
1 A1708300266 RHT FRONT OEM FLOOR OUTLET VENT $35.00
10 NNO EIBACH 15mm STUDS $100.00
1 A1936891508 OEM SHIFTER BEZEL/TRIM $10.00
1 A1937280123 DRIVER SIDE FRONT VENT WINDOW TRIM $38.00
1 68020656AA FOG LIGHT INTERIOR UNIT $25.00
2 5102803AA OEM TWEETERS $24.00
1 A0041535328 OEM OIL SENDING UNIT $85.00
1 2025450104 IGNITION STARTER SWITCH $33.00
1 NNO CHRYSLER LOGO COMPACT/MIRROR $28.00
1 05099158AA OEM HOME LINK MODULE $335.00
1 05097658AA LUGGAGE COMPARTMENT LAMP $24.00
1 NNO OEM HAND/EMERGENCY BRAKE COVER $20.00
1 A1121400060 EMISSION EGR VALVE $85.00
2 1708201826 AMG IGNITION IMMOBILIZER MODULE $95.00
1 ML1033 MANN OIL FILTER KIT $15.00
