Old Mar 5, 2017 | 12:54 PM
onehundred80
Default Re: Aftermarket TPMS
Something to keep in mind. Thanks. But I would prefer psi readings. James
I see that at least some of these give readings in BAR and PSI, you choose in the set up. That plus temp is probably more than required but ...
They look a bit clunky and you probably need a wheel balance if you are particular about added weights on wheels.
Me I'll stick with the OEMs a little bit longer.
