Old Mar 8, 2017 | 01:21 PM
onehundred80
Default Re: Rear wheel bearing tip
Good idea, ideally the face of the weld used for the pull should be square to the bore or the bearing will be harder to pull off and may score the hub surface. Using a lathe to square the surface would be a good idea.
