Thread: Code 3 Pulley
Old Mar 8, 2017 | 06:22 PM
onehundred80
Default Re: Code 3 Pulley
Originally Posted by latemodel21
if the flange of the actual pulley is bent, it seems unlikely that it is serviceable. If you take the belt off, you can spin the pulley with a dial indicator riding on it .... should tell the tale.
Chris
I guess it depends on how much it is bent, a little out of square may be OK as it just holds the dog bines. A judicious rap on the flange in a lathe might be the answer if it is a little too much.
