Old Mar 12, 2017 | 01:33 AM
GraphiteGhost
Default Re: Car will not start
Originally Posted by fastfred
THANK YOU for that input I will do that....
OK, found this thread ( https://www.crossfireforum.org/forum...em-module.html ), check post 44 from 180. There are earlier posts that mention that company that can fix/repair the skreem module as well (make sure it IS the skreem module, for sure). The text for a POSSIBLE reset of the skreem is:
Turned the key with battery disconnected to drain the capacitors. Then connected battery, turned key to on position for several minutes, sounded like things were reprogramming themselves, then turned key off for one minute. Then started car as normal.
I found this in the list of fixes listed by 180 on that link above. Credit given to whomever found this possible fix. IF the RESET try does not work, then you might have to send it out (less expensive) if you have determined the skreem is the problem. The company is also mentioned in the link above, and in the .pdf listed in 180's list of .pdf's. GOOD LUCK!
