Yanksmell
I had intermittent issue with the power seat in the ZH and had enough. When I touch the power seat controls, I want it to do what I want it to do when I want to do it. the idea that I have to open the door with the ignition off or ignition on if the door is closed...enough already!
Remove the lower drivers knee panel and locate the power seat relay to the left of the steering column mounted on a sub plate. Pull the relay and jumper pin 8 to pin 2 (the two middle cavities) with spade connectors and a short piece of #14 wire and done. Your seat will now do whatever you want them to do when you want them to do it without this problematic relay.
The wife is so happy without this German over engineering. I can see safety issues if the seats were memory seats that should not move if the seat belts are fastened. They move when I want them...every time and without that $50 relay.
Great fix option! Many thanks for sharing the information.
