Old Mar 17, 2017 | 12:06 PM
onehundred80
Default Re: Transmission service guide (auto 5 speed).
Originally Posted by JohnGiaccio
Thanks for the reply. To be clear, as I slide the dipstick into the transmission, it comes to a stop, with quite a bit of the dipstick cable staying out. The black portion does not show any signs of being in the fluid at all. By the way, if the entire dipstick is not meant to go all the way in like a traditional dip stick does, then how is anyone supposed to check the level?
If you had a well that was ten feet deep with two feet of water in the bottom and you put a fifteen foot long dry stick down the well until you hit the bottom, how much would the end of the stick get wet?
Or can this test not be done because the stick is too long?
