Old Mar 22, 2017 | 09:17 PM
onehundred80
Default Re: SKREEM replaced RCM rebuilt still won't start
Originally Posted by thegreatjustino
SOS charged $400. I got their name from one of the various SKREEM threads here on the board.
Can you elaborate on the halo?
I've read about a single wire from the ignition switch also possibly being a culprit. Is that what you're referring to?
Depends on what scanner you're referring to. I know there is a scanner that tests the SKREEM (DRBIII ), I don't have access to that. Despite the car not starting, I did plug in my OBD2 scanner and I'm getting a generic 0 dtc code that has no definition.
There is a ring that goes around the ignition switch and from that there is a wire that goes to the SKREEM. If that wire is not connected or is damaged the car will not start. Frankly I do not know if your new symptoms fit the halo absence or not, just a guess really.
