Re: Tire Presure Sensor Question
Just getting around to finally getting these sensors replaced. I understand there are two types from the thread. Schrader and Siemens.
On RockAuto, I see there are a two different types "Direct Fit- Programming Not Required, Relearn Process Still Required" or the "Multi-Fit - Programming Required" So I figured I get some from the Direct Fit parts. There are about 10 types in this section, two from Schrader. Based on the outside look of my wheel, I believe the 20028 part number is the best match. (~$36 each)
Any tips appreciated from you all.
