Connie1004
my car will not go in drive had it 3 days. It shows a black square where the p should be. Tried to do the override with a pen and it did let me shift into drive but square stayed black and wouldn't shift into overdrive. Was scared I was going to mess my trans up. So creeped all the way home. How to fix and how much cost bought car as is.
You have a problem with the transmission itself not the gear changer.
What you have I suspect is the so called Limp Mode, it is intended to save your progress tranny from serious harm.
The answer you had from ala_xfire is probably correct. You vpcan check to see if there are any codes stored using a code reader. If you intend to do work on the car this is what you should buy.
