Re: Help!! Lean afr!!
Hi,
1. check engine codes
2. check/change fuel filter - maybe a clogged fuel filter (happen to me).
i would recommend going from stock fuel filter/regulator to adjustable like Needswings adjustable regulator/filter.
then raise fuel pressure/adjust to the needed afr ratio @ wot (you need a innovate afr controller or similar).
Steven
Berlin Germany
