Old Apr 1, 2017 | 03:15 PM
Wolf_7's Avatar
Wolf_7
Default Re: Help!! Lean afr!!
Originally Posted by No2fast
Hi,
1. check engine codes
2. check/change fuel filter - maybe a clogged fuel filter (happen to me).
i would recommend going from stock fuel filter/regulator to adjustable like Needswings adjustable regulator/filter.
then raise fuel pressure/adjust to the needed afr ratio @ wot (you need a innovate afr controller or similar).
Steven
Berlin Germany
thanks steven, i have stock mann filter with 4 bar inside regulator, i think about adjustable regulator and simple flow filter, but stock fuel pump and injectors can handle good afr to 20 21 psi?
