Re: '05 Convertible top issues
Update:
I topped off the fluid. Unlocking front does nothing to the windows. Switch blinks. Beeping.
With the car running, I manually cycled the top up and down twice to see if the electronics had to be reset, per advice of PizzaGuy. No luck.
Top will not go down with power. However, top did go completely up with the power switch.
I then checked the reservoir and it was back down to the level it was at before I topped it off.
Think I could be dealing with a leak. I pit the top back down and looked at the pistons on each side and they had a bit of fluid. I am guessing they are both leaking. Hard to see any other fluid down there but the fluid was clearly visible there. Are there other areas I should check for leaks?
Since nothing happens with the top or windows when it is unhooked from the windshield, can I now assume that the switch is bad there?
You advice and help is appreciated!
Thanks.
