GraphiteGhost
As long as your doing the oil/filter change, spend the bucks to do the plate/connector as well. This way, if the oil/filter didn't fix your issues, the plate with the connector should. It'll save you another oil servicing as a minimum and will eliminate the plate/connector issue as well. That's my $.0.02 worth!
Good advice -- I've seen the plate and connector plug on ebay for ~$65
