Old Apr 11, 2017 | 09:40 AM
chturner's Avatar
chturner
Default Re: Car shut off during idle
Tried to start the car again last night.. started right up like it should. Let it idle and hit the gas every few seconds. Throttle was responsive at first but slowly started bogging down more and more each time I hit the gas pedal. Went ahead and backed into the garage, tried hitting gas one more time after it was in park and it died. After I came inside, I was doing some browsing on the forum and noticed that most people who had bad fuel pumps did not get a code. One in particular that had the same symptoms as mine was solved with a new MAF sensor although his mom's car didn't show a code like mine is (https://www.crossfireforum.org/forum/troubleshooting-technical-modifications/76014-need-new-fuel-pump-please-help.html) ... I'm hoping that is the case on mine. I'm having the RCM soldered today at school and hopefully I can find a scan tool somewhere in this little town so I can give you guys a code. Check back in later!
