Old Apr 11, 2017 | 11:49 AM
chturner's Avatar
chturner
Default Re: Car shut off during idle
Forget the gas it is fine, what is six months.
I'd normally hazard a guess that it is a fuel pressure or volume problem. The only thing wrong with that is that it sat and then suddenly had a problem.
So I remembered that years ago my exhaust was plugged with ice and I had a similar problem and here on the forum someone had dog food stored in his muffler by a rodent of some form and it caused the same problem, I also found a lot of seed stored in my engine cover that was not in use at the time. Back pressure caused the engine to stall.
So these are possibilities to look for.
Did not think of those pesky things causing problems like that. I'll have to check that out. I'll check air filter and exhaust when I get home. Is it possible that something like dust or an object got stuck in the air filter, sucked into the MAG sensor and disrupted it? That would explain the code right? Hopefully I'll be able to pinpoint the code later on.
