Old Apr 14, 2017 | 07:33 PM
onehundred80
Default Re: Rear drive shaft/U-joint
Here's a explanation of why a "guibo" is used in a driveshaft assembly:
"A giubo (/ˈdʒuːboʊ/ JEW-boh; etymology: giunto Boschi), also known as a flex disc, and sometimes misspelled as guibo, is a flexible coupling used to transmit rotational torque between the drive shaft and the companion flange on mechanical devices, such as an automobile engine.
The giubo is made from flexible synthetic rubber and is designed to allow some angular misalignment while reducing driveline vibration in mechanical power transmission applications."
Not bad for a South Carolinian!
Design approach has been around for awhile. When I had the 3 Merkur XR4Ti's, the driveshaft had a guibo in it. Only issue was Ford wouldn't sell you the guibo. You had to buy the entire driveshaft from them. And so like the Crossfire Owners, the Merkur Owners Group learned where to get the guibos & how to disassemble & re-assemble the driveshaft. We usually replaced the center support bearing while we were down there.
Not bad for a Carolinian? Even though you had the right spelling in the blurb you found you still misspelled it before and after the blurb. LOL
