Old Apr 15, 2017 | 09:47 AM
Kgalliher519's Avatar
Kgalliher519
Default Re: Stumbled upon you guys while trying to fix my xfire
Ok. I pulled the rcm to check the 3 'trouble points, they had a good cover on them. When I turn the key the engine will crank to try to start twice without firing up and then on the 3rd try it won't even try to crank. If I disconnect both terminals on the battery to reset the system and try again it will repeat what said before. 2 cranks, no start then no crank
