Old Apr 16, 2017 | 09:29 PM
roberto's Avatar
roberto
Default Re: Stumbled upon you guys while trying to fix my xfire
if it is an RCM failure the fuel pump is not getting power, easy check, put 12v on the power term of fuel pump, if the engine starts the RCM is bad(relay not energizing). probable fix is the solder job. Fuel pump located right rear underside under removable panel.
