Old Apr 18, 2017 | 10:49 AM
Goldwing's Avatar
Goldwing
Default Re: Finally installed the low beams correctly!!
I can understand that, especially if you have "big hands" (no Trump joke here). After a couple times doing this, the roadster was relatively easy especially after moving the radiator hose on the passenger side. It takes less than 10 minutes per light. The SRT6 is more of a challenge - there is some kind of air pump directly behind the driver light and it has to be unbolted and moved out of the way first. I also have one of the small running lights over the headlight out and have to figure out how to access that...eventually.
