zip439
I have a 2005 Graphite Metallic coupe. A few months back I removed my right rocker panel and repaired large scratch, and repainted. I used Chrysler touchup spray paint: code ZDR which is the Crossfire code, but it is also a Viper color, part # E04889703AA. It is a lacquer and when sprayed comes out of the can in a very fine mist. From my perspective it is a perfect match. One can did the entire rocker panel. I went over it with Duple-Color Perfect Match clear coat, an acrylic lacquer. All in all it looks like OEM original.
Earlier in the year I removed the windshield trim and the door handles. Sprayed them with my gun using a mixed one step paint. I need to go back and look in my paint locker to see the exact brand and number, but it was mixed using the Crossfire color code. That is completely different than OEM. Has much more metal flax look to it, but I like the extra shine so have keep it on the car. Most people wouldn't notice the difference, but it is definitely there. A single coat process vice a two step base/clear will always show a difference. I thought a single step paint will hold up better on the windshield trim.
Maybe, but I always thought the reason they went to the 2 step process was increased durability. Those high solids clears are like a thick plastic coating. I use as much as 7 coats of clear, especially on leading edges.
