Old Mar 14, 2004 | 03:37 AM
Cyril Baldwin's Avatar
Cyril Baldwin
Default
My problem there is reconnecting the wire since its a small hole, I need longer fingers to attach it to the bulb. :roll: If I can only remove the coolant reservoir, that can give me more space to work on and I maybe able to use a long nose pliers to attach the bulb and wire back.
TIP: Before removing your high beam bulb, apply a masking/duct tape or pack the hollow portion below the bulb with a face towel to catch any part that might fall in the bottom space of the headlight housing. In that way, you won't be fishing for any object that has fallen underneath the housing.
