Old May 3, 2017 | 10:44 PM
onehundred80
Default Re: Good way to remove power steering fluid?
I intend to use my topsider to suck out as much as I can, not a perfect solution but at least the mix of old and new oil will be better the what is in there now. If it requires less than 1/2 a litre then I shall drive it a bit and do it again. With less than 35,000 miles the oil should not be too bad anyway.
