Old May 4, 2017 | 09:09 AM
amx1397
Default Re: killer chiller and our IAT's
Originally Posted by Gull wing
Jim, I cant fully figure out the killer chiller working principle, are there ac hoses running inside the box? if so, do the killer chiller work only when the air conditioner is on? (then the hoses should get cold when a/c on and cold ac hoses would make the water running in the box colder)
it is like two ac's like a van with the rear AC
you tap into both the low and high side of your ac hoses (this requires an extra pound of Freon) somewhere in the front (mine is under the headlight is the Killer chiller) the KC has freon lines going to your ac ,,,and has water lines going to your supercharger pump,, to the tank,,, to the KC (i do not have a heat exchanger ) you could say i have the killer chiller in place of my heat changer , if you have your supercharger cooling system isolated from the car 's cooling system then you are half way there. jim
