kingtj
I actually took the car to him to have the work done, even though he usually does mobile work. (He's a lot cheaper if you come to him and drop it off.)
I'm not sure if he'd be willing to drive out to me without charging a trip charge, just because I have a concern his work might have caused my new problem....
That's why I thought I'd run it by people here who might know more about it. Again, I'm not seeing any oil leaking anyplace, and I had a few occasional, random issues with the car's RPMs suddenly dropping and making a quick shudder when slowing to a stop at a stop light or sign, before I had the gasket repaired. (I was advised that those "hiccups" could have been caused by oil seeping down and getting onto a spark plug -- hence motivation to get the gasket fixed sooner rather than later.)
If this turns out to be a vacuum leak or something, I'd rather not get stuck paying him to diagnose and/or fix it and bill me. But if this sounds like a case of, "Yep..... he screwed up. Been there, seen that." -- then I'll call him right away!
Just a Q? Did you remove the engine cover to see if there is any 'weeping' on the top side of the covers? Also, while the cover is off, check if any hoses were left off/came off. I would do this before calling him. Good luck!
