Old May 6, 2017 | 12:14 PM
amx1397
Default Re: killer chiller and our IAT's
Originally Posted by Morphh
U have one IC pump or 2 ?
i have c32 I could put bat in trunk and put water box in its place then, like u did.
I assume you have the intercooler water separated, this is the only way this KC works , then you put the kc in place of the heat exchanger the rest of your water system stays the same. if you order a Killer chiller tell joe (the owner0 you would like a discount as jim with the crossfire, told you to call. not promising the discount but try. you will get all the instructions with a kc. jim
