Re: Need Help - P0410 Code Again
STOP THE PRESSES! Pulled the RCM again to check fuses, connections and solder joints. Using as much magnification as I could find DISCOVERED that a couple of pins associated with the air pump relay were suffering from what appears to be fractures from cold solder joints as has been previously identified. Cleaned these up and resoldered --- I'm betting this will solve my P0410 code - wish me luck.
