Old May 10, 2017 | 09:44 PM
  #40 (permalink)
TheThomaswastaken's Avatar
TheThomaswastaken
Default Re: Help With Tire Purchase
Fair warning. 285 rear tires might rub if you're too low on both inboard and out oard wheel well.
Rear tire 285 width at lowest setting using very old set of ground control adjustable spring which caused rubbing until radials were exposed.
Ignore the baldness of the tire in general, the point here is that 285 rear tires on a Crossfire with a bottomed out suspension will rub inside wheel well and outer wheel well also. These tires were driven until they blew out.
