Re: Power Seat Relay
The relay cost $25. through RockAuto. It takes about an hour to drop the panel underneath the dash on the driver side. I would give it a try. If that doesn't work, I would unbolt the driver side seat, make sure the connections are snapped tight & no bare wires showing. If there is no problem there, then it must be the car seat switch which can be purchased on e--bay. Since you are a new Crossfire owner, I would suggest you purchase a set of shop manuals on e-bay Some are new, some are old; they cost between $50 & $100.
