Dash lit ups with lights
Hi all,
Need some help here as I tried following the throttle reset instructions and now my dash is lit up with the following lights brake light appears along with check engine , brake wear , abs , bas esp , and speedometer / odometer stops working as well as the Spoiler is up with red light blinking on the switch. I have read up and tried steering wheel reset, cleaning all grounds as well as replacing the battery with nothing working. When we look for codes it is P0600 but I cannot find any good suggestions as to what would be causing the code. Any help would be appreciated.
This is for a 2005 Limited , N/A with 6 speed.
Thanks
