tunaglove
Walbro 255 pump, 6an fuel lines, adjustable fuel regulator set to 60psi , boost monkey fuel rail, and 2006 e55 injectors. I want to go stacked pulleys and e85 so I'm slowly building up the fuel system.
You accounting for the additional 35% fuel volume you need with E85 to at least match kW output?
Following someone else's success, or your own engineering?
